• Had a good one this morning.
    Customer complaint was very incomplete on the WO.
    All that I could get from them was some kind of braking problem.
    The key turned out to be "she almost got into a wreak" the other day.
    She stated that this small car should STOP better.
    Took the car out for a test drive
    humm I did not notice any kind of problem with the braking.
    There was no shaking due to warped rotors..great pedal height and it stopped just fine.
    I thought about the situation for a second. Ok maybe 15 minutes.
    Then a flash thought came into my mind....checked the anti-lock system.
    Yep the system worked.
    Several weird noises and a pulsating pedal.
    Went back to the shop with the results...............
    You got to enjoy working with the general public.
    Allons
