Need some help. 70 GT. Haven't had dash lights in a while, pulled the instrument panel and went through everything. Fixed some wires and connectors, replaced a fuse and fixed a bad connection/ground and dash lights now work better than they ever had. Not the problem. Also replaced battery that wasn't holding a charge, several years old. Here's the problem. Now fuel/temp gage doesn't work. Did before this. All the other gages work, Well, except the clock and it hasn't worked s...ince I got the car years ago. Can see a minute movement on the fuel gage backwards. Didn't mess with those wires but checked them anyway and they are installed right. Reversing the wires does the same thing, minute movement backwards. Applied a couple volts direct to the gage and it works. Pulled and physically checked all the fuses, all good. Have voltage to the gage but still doesn't work. Everything seems to check out. What am I missing?
