What are some good cooling system ideas? Any good aftermarket radiators? My next purchase will probably be a shroud and an electric fan. Would removing the thermostat help keep it cooler in the summer?
Cooling system upgrades
OGTS has a multicore aluminum radiator. Some have adapted a Honda aluminum radiator (eBay).
You definitely need the stock shroud. Did you keep the heat shield under the Weber?
car did not have a shroud to begin with,well be on my order list, and there was no hear shield under the weber
I'll look and see if I have a shield and shroud. won't be till Tuesday though..
I'm going to get a universal electric fan tuesday, a shroud would be awesome. 86 bucks opel gt source
ended up buying, 160 thermostat and gasket, painted housing, 7 blade fan, shroud, 10inch electric fan, waterpump and gasket, alternatir rubber mounts, fanbelt, flushed radiator 3 times. And liwer radiator mount last parts ship in friday. Il install monday
I finally found a GT shroud if you still need one.
thanks, ended up getting one from opel gt source. Come to find out my gauge was reading 20 degrees hotter then it really was haha. Used a temp gun to read.
