OK. I have 6 2.3L cranks and will be trying to clear out all my stuff.
I will have all the cranks balanced, offset ground to fit BMW M10 rods, and have the weights shaved to fit the 1.9L Block better, they will come with the main bearing set and shims as shown above : $1300
If interested in a 2.3L Crank to have your own machine shop build to different recipe.. the crank itself with no bearings - $600
As you can see the 2.3L Cranks is a bit bigger than the 1.9L/2.0L Crank..
